Using version 6.2; when I first open the VBA Editor in an Intellicad session (whether from menu, command bar, or Alt+F11) I get the following error:
"Packaging Wizard" with the following text; "Object doesn't support this property or method"...I hit the "OK" button, editor opens and everything is fine...this also happens in version 5.1.
Any thoughts?
Thank you,
ssc
ssc,
Are there any add-ins listed in the VBAIDE?
I am now guessing:
When you install IntelliCAD; CMS have a batch file that runs vba6.msi after installing IntelliCAD; maybe something went wrong during installation of the VBA program.
You could try to install VBA manually.
Find the file vba6.msi (In the ICAD\Vba folder where ever you installed ICAD ) and double click on it.
Hope this helps.
I am now guessing:
Hope this helps.
