Trying to keep SelectionSet to impleidselection after a command ends, but it is not retaining the selectionset.
Objects selected after simple command does not keep selected.
Is ther a way to set the PROPERTIES filter objects ?
<CommandMethod("CheckForPickfirstSelection", CommandFlags.UsePickSet)>
Public Sub CheckForPickfirstSelection()
'' Get the current document
Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
'' Get the PickFirst selection set
Dim acSSPrompt As PromptSelectionResult
acSSPrompt = acDocEd.SelectImplied()
Dim acSSet As SelectionSet
'' If the prompt status is OK, objects were selected before
'' the command was started
If acSSPrompt.Status = PromptStatus.OK Then
acSSet = acSSPrompt.Value
Application.ShowAlertDialog("Number of objects in Pickfirst selection: " &
acSSet.Count.ToString())
Else
Application.ShowAlertDialog("Number of objects in Pickfirst selection: 0")
'' Clear the PickFirst selection set
Dim idarrayEmpty(0) As ObjectId
acDocEd.SetImpliedSelection(idarrayEmpty)
'' Request for objects to be selected in the drawing area
acSSPrompt = acDocEd.GetSelection()
Application.ShowAlertDialog("Number of objects selected: " &
acDocEd.SetImpliedSelection(acSSet)
Else
Application.ShowAlertDialog("Number of objects selected: 0")
Re: Editor ImpliedSelection
#2Simply add the CommandFlags.Redraw to the CommandMethod,
It works as should be.
[CommandMethod("PFA", CommandFlags.Modal | CommandFlags.UsePickSet | CommandFlags.Redraw)]
End SubRe: Editor ImpliedSelection
#3After command ends the selected objects does not keep selected ... it is released...
#4Here's the screenshot on IntelliCAD 11:
https://www.dropbox.com/s/peivwgjiiycpg ... d.mp4?dl=0
#6Hi Denis,
Sorry, it didn't work on IntelliCAD 10.0.
Please upgrade to IntelliCAD 11 to have the new features and improvements.
Regards.
Regards.
