SYSVAR or setting for alert box?
I'm still fine tuning my settings after upgrading to v11.1 Pro, I am getting an alert box that is
very annoying eg. I window 30 entities and use the properties dialog box to change their layer
to a layer which is frozen, this box pops up 30 times, 1 time per entity, I have to hold the
escape key down for a while while it flashes on/off. I don't know what the alert box is called
so I can't disable it, any ideas?
CMS IntelliCAD
Selected entities changed to a frozen or off layer.
BTW, where is an easy site I can put an image so I can embed it here?
-=(RH)=-
-=(RLH)=-
Re: SYSVAR or setting for alert box?
Yes! Thank you Quan!
That worked, I had never heard of that setting before.
Where do you park your image so the URL can be used for this forum?
I tried to drag and drop a small .png file into an earlier post and it didn't work.
Thanks,
~RH~
QuanNguyen wrote:
Sat Feb 11, 2023 8:19 pm
Hi ,
Please set the system variable LAYEROFFORFROZENNOTIFY = 0 to turn off the dialog box message.
-=(RLH)=-
