Hello CMS
I have installed the license on the laptop and want to transfer it to the USB dongle.
Is this possible?
I already use USB Dongle Maker software and follow USB dongle maker instructions, but still cannot use it.
Sometimes error ActSvr: Invalid Registration ID! and ActSvr: All activations are used up!
Can you guide me step by step how to transfer the license to dongle?
I will deactivate my license now
Cheers and Thanks CMS Team
Re: Transfer License form laptop (CMS 13 PE) to USB dongle
#2Well, howdy! If you're experiencing problems copying your license to the USB dongle, it might be because of this. Please be sure that no steps are being overlooked by double-checking the instructions provided by the USB Dongle Maker software. If you continue to encounter the issues, contacting CMS support directly may provide you with a personalized step-by-step tutorial. Hopefully, things will become clear for you soon. Best of luck! Thank you!
#3Make sure that you have properly deactivated the license on the laptop. Sometimes, the software might not completely release the license until you perform the deactivation steps correctly.
#5Is there a way to check if the license was successfully deactivated on the laptop before trying to use the USB dongle?helendam wrote: ↑Mon Jan 06, 2025 9:26 pmMake sure that you have properly deactivated the license on the laptop. Sometimes, the software might not completely release the license until you perform the deactivation steps correctly.sarkari result
