Re: Transfer files dwg from Intellicad to 3ds Max
andcip wrote:
Mon Jul 03, 2023 12:51 pm
Good morning everyone. I haven't downloaded the program yet, I would use it for 2D and 3D drawing. Can anyone tell me if the dwg file is compatible with the "Import > Link AutoCAD" function on Autodesk 3dsmax, to import dwg files? Anyone use flash games?
Good morning! 😊 Yes, DWG files are compatible with the "Import > Link AutoCAD" function in Autodesk 3ds Max. You can link a DWG file into a 3ds Max scene by going to **File > Import > Link AutoCAD**. This allows you to maintain a "live" link between AutoCAD and 3ds Max, so any changes made to the DWG file will automatically update in 3ds Max Files - Autodesk Knowledge Network](https://help.autodesk.com/cloudhelp/202 ... 3BF6E9.htm).
[/quote]
Hi, thank you for your reply. In the meantime, I checked the compatibility with 3dsmax, and everything works fine with the dwg link. Intellicad has the same "display resolution" parameters as Autocad.
