I am having difficulty opening a second drawing from within VBA. I have successfuly performed a SAVEAS on the first drawing and need to open a different template drawing. the command line I have been trying is:
Application.Documents.Open "C:\My Documents\Materials\auto second.dwg"
This does open the drawing but creates the following error message:
Run-Time error '5':
invalid procedure call or argument
I have tried "on error resume next", but nothing seems to work.
Thanks for your help.
Try
Sub OpenDrawing()
Dim objDrawing As Document
Dim strDrawingName As String
strDrawingName = "C:\My Documents\Materials\auto second.dwg"
' Loop through each Document to see if drawing has been opened
' If not then open it
For Each objDrawing In Documents
If objDrawing.Name = "auto second.dwg" Then
MsgBox "Drawing Already Open", vbInformation
Exit Sub
Next
Application.Documents.Open (strDrawingName)
Sub OpenDrawing()
Exit Sub
Next
