Blocks.Add method
I am trying to create a Block in Cadopia 6 Pro.
Here is the stripped down code I am using:
Dim CurrentDwg As Document
Dim TempBlock As IntelliCAD.Block
Dim InsertPoint As IntelliCAD.Point
Set CurrentDwg = Application.ActiveDocument
Set InsertPoint = Library.CreatePoint(0, 0, 0)
Set TempBlock = CurrentDwg.Blocks.Add(InsertPoint, "FOOBAR")
The last line produces the following error message:
Run-time error '-2147467259(80004005)':
Method 'Add' of Object "IIcadBlocks' failed
(Whew! That's a great error number!)
I have also tried this:
Set TempBlock = IntelliCAD.Blocks.Add(InsertPoint, "FOOBAR")
Same error.
This sure looks like the same sort of code in the Developer's
Reference.
Can someone show me the error of my ways?
Thanks in advance.
Steve,
It appears that you need an insert object
Dim blockObj As IntelliCAD.Block
Dim insPt As IntelliCAD.Point
' Insert the block
Dim blockRefObj As IntelliCAD.BlockInsert
Set blockRefObj = ThisDocument.ModelSpace.InsertBlock(insPt, BlkName, 1, 1, 0)
ssc
ssc -
Thanks for the response. I am trying to create a Block, not just Insert it.
In other words, I am trying to create a Block object using VBA code, not just place an existing Block somewhere in the .DWG.
I know I can use a template .DWG to get around this (which I am currently doing), but the basic code I am working with runs OK in ACAD and I would like to port all of the program (if possible) directly to ICAD.
Mostly curious about what I am doing wrong.
