Hi, I´m having a problem seeing my linetypes correctly in the viewport. In model, I have hidden lines that once i go to vp, they appear to be continuous. So all lines once I plot are continuous!
can anyone help?
While in your model space tab, type "PSLTSCALE" into the command prompt. Make sure the value is set to <OFF>
When this value is set to <ON>, I believe Intellicad renders your model space line types at the scale you're using in paper space. If you're like us and insert your sheets at 0.1 scale, then using this option will definitely make all your line types appear continuous. The reality is they're just all being drawn as if at .1 scale.
Dell Optiplex 745
Windows XP Professional SP3
Intel Core2 6400 @ 2.13Ghz
4GB RAM
Nvidia GeForce GT 610
[I'd rather be on my home computer]
(I do not represent CMS or it's affiliates)
4GB RAM
it didn´t work. Although it was set ON. I don´t really understand what you ment with "insert your sheet at 0.1 scale"...
I go to my paper space and if I want to print in A3 I draw my sheet, 0.297,0.42 and open my viewports inside that sheet limit.
Is there any other value i should change? I looked down in youtube and couldn´t finde intellicad answers, but for autocad it was pretty simple, the video said to type Lt and once in the linetype manager, go to "show detalis" and be sure the box of "use paperspace units for scaling"had no tic.
could´t find "show details" or box in iltellicad linetype manager. I´m really desperate!!!
