Autocad toolbars
I would like to import my Autocad LT or 14 toolbars into intellicad, Is this possible?
I am having trouble with the Intellicad tool buttons looking so different than my Acad buttons. Thanks in advance for any help I may recieve.
Yes and no. It is possible to import the toolbars, but preparing the necessary menu files takes a lot of work. I created the missing UCS toolbar in Intellicad on the basis of the Autocad one, you can have a look at the syntax in the ucs.mnu file. The icon bitmaps of each toolbar button has to be in the Intellicad folder, and referenced properly in the menu file you create. An extract of Autocad button images can be found in the link below.
AutoCad bitmaps and icons
UCS Toolbar
Another problem with using the same toolbars is the command names may be different so they won't work if they are but if you can figure out all the details on the command names and stuff you can do it. It isn't an easy process. When I learned on how to do these things it help me understand how the program works a little better. So the best of luck to you.
