I am trying to add a PREVIEW image to my DCL box.
I have created a simple dcl/lsp to display a '.sld' file (50x50x6.sld, one I already had)
DCL
new1 : dialog { //dialog name
label = "image" ; //give it a label
: row { //begin row
: image { //define image tile
key = "im3" ; //give it a name
height = 12.0 ; //add a height
width = 25.0 ; //and now a width
fixed_width = true; //fix the width
fixed_height = true; //fix the height
color = 251; //graphics_background; //set background color
} //end image
} //end row
ok_cancel ; //predefined OK/Cancel button
} //end dialog Code: Select all
(defun C:new1 ()
;define function
(setq dcl_id (load_dialog "new1.dcl"));load dialog
(if (not (new_dialog "new1" dcl_id) ;test for dialog
) ;not
(exit) ;exit if no dialog
) ;end of if
(setq w (dimx_tile "im3") ;get image tile width
h (dimy_tile "im3") ;get image tile height
);end of setq
(start_image "im3") ;start the image
(slide_image 0 0 w h "50x50x6.sld") ;display a slide
(end_image) ;end image
(action_tile
"accept" ;if O.K. pressed
"(done_dialog) (setq userclick T)"
;close dialog, set flag
) ;end of action tile
(action_tile
"cancel" ;if cancel button pressed
"(done_dialog) (setq userclick nil)";close dialog, lower flag
) ;end of action_tile
) ;end defun
;(princ)
Now to add this to the main project, see previous post!
Here is my DCL
:row {
:column { :text {label="PREVIEW";alignment=centered;}
:image {
height=16.0;
width = 50.0 ;
color=1;
key="imagekey";
:column {
: list_box {
label = "Sizes";
width = 22;
height = 12;
key = "get_size";
}and my LSP
) ;end CHECK_SELECTIONS
(defun SET_IMAGE ()
(setq w (dimx_tile "imagekey") ;get image tile width
h (dimy_tile "imagekey") ;get image tile height
) ;end of setq
(start_image "imagekey") ;start the image
) ;End SET_IMAGE
(defun DIALOG ()
Any pointers to where I'm going wrong?
S
