Re: Steel Section Data base
Found through experimentation.
Open the steel dialogue. Then 'right click' anywhere on the dialogue, then de-select the 'Metric Data'
All should now display Imperial measurements.
NOTE: This setting does NOT appear to be saved, so you will need to repeat each time you open the Steel dialogue.
Steve
sln8458 wrote: ..........
Thank for your experimentation, Steve,
But on my side, this setting already saved, it opens the last dialogue setting.
QuanNguyen wrote: ↑
Tue Oct 13, 2020 7:44 am
I have just double checked, closing Icad between tests and the setting is NOT saved.
I set to imperial, closed dialogue, saved drawing and exit.
Restart Icad, open steel dialogue and it displays metric units.
NOTE: I am running the trial version of 10 if that makes any difference??
S.
