Re: AcquirePoint
#17Hi,
Can you attach your code here then someone can find/debug where the issue does?
Re: AcquirePoint
#18Code: Select all
Public Class MoveRotationScaleJig
Inherits DrawJig
#Region "Fields"
Private mBase As teigha.geometry.point3d
Protected mEntities As New List(Of Entity)()
Private mTotalJigFactorCount As Integer = 3
Private mCurJigFactorIndex As Integer = 1
' Jig Factor Index
Public mLocation As teigha.geometry.point3d
' Jig Factor #1
Public mAngle As [Double]
' Jig Factor #2
Public mScaleFactor As [Double]
' Jig Factor #3
#End Region
#Region "Constructors"
Public Sub New()
MyBase.New
'Dim _ed As Editor = IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
'AddHandler _ed.PointMonitor, New PointMonitorEventHandler(AddressOf ed_PointMonitor)
'Public Sub ed_PointMonitor(sender As Object, e As PointMonitorEventArgs)
' mLocation = e.Context.ComputedPoint
'End Sub
Public Sub New(basePt As Point3d)
mBase = basePt.TransformBy(UCS)
'TODO: Initialize jig factors and transform them if necessary.
mLocation = mBase
mAngle = 0
mScaleFactor = 1
#End Region
#Region "Properties"
Public Property Location() As teigha.geometry.point3d
Get
Return mLocation
End Get
Set
mLocation = Value
End Set
End Property
Public Property Angle() As [Double]
Get
Return mAngle
End Get
Set
mAngle = Value
End Set
End Property
Public Property JigFactor As Integer
Get
Return mTotalJigFactorCount
End Get
Set(value As Integer)
mTotalJigFactorCount = value
End Set
End Property
Public Property ScaleFactor() As [Double]
Get
Return mScaleFactor
End Get
Set
mScaleFactor = Value
End Set
End Property
Public Property Base() As teigha.geometry.point3d
Get
Return mBase
End Get
Set
mBase = Value
End Set
End Property
Public ReadOnly Property AcEditor() As Editor
Get
Return MgdAcApplication.DocumentManager.MdiActiveDocument.Editor
End Get
End Property
Public ReadOnly Property UCS() As Matrix3d
Get
Return AcEditor.CurrentUserCoordinateSystem
End Get
End Property
Public ReadOnly Property IcEditor As Editor
Get
Return IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
End Get
End Property
Public Property TotalJigFactor As Integer
Get
End Get
End Set
End Property
Public ReadOnly Property Transformation() As Matrix3d
Get
'return Matrix3d.Identity; //* Change it to anything else meaningful.
Return Matrix3d.Scaling(mScaleFactor, mLocation).PostMultiplyBy(Matrix3d.Rotation(mAngle, Vector3d.ZAxis.TransformBy(UCS), mLocation)).PostMultiplyBy(Matrix3d.Displacement(mBase.GetVectorTo(mLocation)))
End Get
End Property
Public Property Entities() As List(Of Entity)
Get
Return mEntities
End Get
Set(value As List(Of Entity))
mEntities = value
End Set
End Property
#End Region
#Region "Methods"
Public Sub AddEntity(ent As Entity)
ent.TransformBy(Intellicad.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem)
mEntities.Add(ent)
Public Sub TransformEntities()
Dim mat As Matrix3d = Transformation
For Each ent As Entity In mEntities
ent.TransformBy(mat)
Next
#End Region
#Region "Overrides"
Protected Overrides Function WorldDraw(draw As WorldDraw) As Boolean
Dim geo As WorldGeometry = draw.Geometry
If geo IsNot Nothing Then
geo.PushModelTransform(mat)
geo.Draw(ent)
Next
geo.PopModelTransform()
Return True
End Function
Protected Overrides Function Sampler(prompts As JigPrompts) As SamplerStatus
Select Case mCurJigFactorIndex
Case 1
Dim prOptions1 As New JigPromptPointOptions(vbLf & "Move:")
' Set properties such as UseBasePoint and BasePoint of the prompt options object if necessary here.
prOptions1.UserInputControls = UserInputControls.GovernedByOrthoMode Or UserInputControls.GovernedByUCSDetect
'prOptions1.UserInputControls = UserInputControls.GovernedByUCSDetect Or UserInputControls.UseBasePointElevation Or UserInputControls.Accept3dCoordinates
prOptions1.UseBasePoint = False
Dim prResult1 As PromptPointResult = prompts.AcquirePoint(prOptions1)
If prResult1.Status = PromptStatus.Cancel AndAlso prResult1.Status = PromptStatus.[Error] Then
Return SamplerStatus.Cancel
'If prResult1.Value.Equals(mLocation) Then
If Not mLocation.IsEqualTo(prResult1.Value, New Tolerance(0.000000001, 0.000000001)) Then
'Use better comparison method if necessary.
mLocation = prResult1.Value
Return SamplerStatus.OK
Else
Return SamplerStatus.NoChange
Case 2
Dim prOptions2 As New JigPromptAngleOptions(vbLf & "Rotate:")
prOptions2.UseBasePoint = True
prOptions2.BasePoint = mLocation
prOptions2.UserInputControls = UserInputControls.GovernedByOrthoMode Or UserInputControls.GovernedByUCSDetect
Dim prResult2 As PromptDoubleResult = prompts.AcquireAngle(prOptions2)
If prResult2.Status = PromptStatus.Cancel AndAlso prResult2.Status = PromptStatus.[Error] Then
If prResult2.Value.Equals(mAngle) Then
Else
mAngle = prResult2.Value
Case 3
Dim prOptions3 As New JigPromptDistanceOptions(vbLf & "Scale:")
prOptions3.UseBasePoint = True
prOptions3.BasePoint = mLocation
prOptions3.UserInputControls = UserInputControls.GovernedByOrthoMode Or UserInputControls.GovernedByUCSDetect
Dim prResult3 As PromptDoubleResult = prompts.AcquireDistance(prOptions3)
If prResult3.Status = PromptStatus.Cancel AndAlso prResult3.Status = PromptStatus.[Error] Then
If prResult3.Value.Equals(mScaleFactor) Then
Else
mScaleFactor = prResult3.Value
Case Else
Exit Select
End Select
End Function
#End Region
#Region "Commnads"
Public Sub Jig()
Try
If PrivateJig() Then
TransformEntities()
Catch ex As System.Exception
IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString)
End Try
Public Function PrivateJig() As Boolean
Try
Dim pr As PromptResult
Do
pr = AcEditor.Drag(Me)
' Keyword handling code
If pr.Status = PromptStatus.Keyword Then
Else
Me.mCurJigFactorIndex += 1
Loop While (pr.Status <> PromptStatus.Cancel AndAlso pr.Status <> PromptStatus.[Error]) AndAlso Me.mCurJigFactorIndex <= Me.mTotalJigFactorCount
If Me.mCurJigFactorIndex = Me.mTotalJigFactorCount + 1 Then
Return True
Else
Return False
Catch
Return False
End Try
End Function
#End Region
#Region "Commands"
<CommandMethod("TestMoveRotationScaleJig_Method")>
Public Shared Sub TestMoveRotationScaleJig_Method()
Dim Doc As Document = IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim db As Database = Doc.Database
Dim ed As Editor = MgdAcApplication.DocumentManager.MdiActiveDocument.Editor
If Not Doc.IsActive Then
Try
Dim selRes As PromptSelectionResult = ed.GetSelection()
If selRes.Status <> PromptStatus.OK Then
Return
Dim prOpt As New PromptPointOptions(vbLf & "Base point:")
Dim pr As PromptPointResult = ed.GetPoint(prOpt)
If pr.Status <> PromptStatus.OK Then
Return
Dim jigger As New MoveRotationScaleJig(pr.Value)
For Each id As ObjectId In selRes.Value.GetObjectIds()
Dim ent As Entity = DirectCast(tr.GetObject(id, Teigha.DatabaseServices.OpenMode.ForWrite), Entity)
jigger.AddEntity(ent)
Next
'jigger.Jig()
tr.Commit()
End Using
ed.WriteMessage(ex.ToString())
End Try
Public Shared Sub MoveRotationScaleJig_Method(BasePoint As Point3d, Entities As List(Of ObjectId))
Dim db As Database = HostApplicationServices.WorkingDatabase
Try
Dim jigger As New MoveRotationScaleJig(BasePoint)
For Each id As ObjectId In Entities
Dim ent As Entity = DirectCast(tr.GetObject(id, teigha.DatabaseServices.OpenMode.ForWrite), Entity)
Next
'jigger.Jig()
tr.Commit()
End Using
End Try
#End Region
End Class
Re: AcquirePoint
#19Code to create Pallete
Private Sub LigaçõesToolStripMenuItem1_Click(sender As Object, e As EventArgs) Handles LigaçõesToolStripMenuItem1.Click
Hide()
CommandMethods.CreatePaletteLigacoes()
End SubRe: AcquirePoint
#20Code: Select all
Public Shared Sub CreatePaletteLigacoes()
Dim ps As IntelliCAD.Windows.PaletteSet
' ps = New Intellicad.Windows.PaletteSet("My Palette")
ps = New IntelliCAD.Windows.PaletteSet("Ligações", New System.Guid("F69E9148-2DF8-4911-8442-8C97AF23C2EE"))
ps.Style = IntelliCAD.Windows.PaletteSetStyles.ShowPropertiesMenu Or
IntelliCAD.Windows.PaletteSetStyles.ShowAutoHideButton Or
IntelliCAD.Windows.PaletteSetStyles.ShowCloseButton
'ps.Opacity = 90
'ps.Size = New System.Drawing.Size(250, 400)
' ps.MinimumSize = New System.Drawing.Size(225, 400)
'//ctrl.Dock = System.Windows.Forms.DockStyle.Fill
Dim uc1 As New ucLigacoes
Dim p1 As IntelliCAD.Windows.Palette = ps.Add("Ligações", uc1)
'//You may Or may Not need the below code for list/combo boxes to retain focus.
'ps.KeepFocus = True
ps.Visible = True
#21Hi,
Try to replace the Jig with this one:
and the command method:
Public Function Jig() As Boolean
Try
Do
Else
Return True
Else
Return False
Catch
Return False
End Try
End FunctionCode: Select all
<CommandMethod("TestMoveRotationScaleJig")>
Dim ed As Editor = CadApp.DocumentManager.MdiActiveDocument.Editor
Try
Return
Return
Dim ent As Entity = DirectCast(tr.GetObject(id, OpenMode.ForWrite), Entity)
Next
If jigger.Jig() Then
jigger.TransformEntities()
tr.Commit()
End Using
End Try
#22Still same result ... unfortunately.
I saw your ScreenShot thousands of times ...
Here my ScreenShot:
https://drive.google.com/file/d/1aTQTMa ... sp=sharing
Check it out !!
Here my ScreenShot:
Check it out !!
