by railbuff
Hi John,
Really appreciate your help. Am still not understanding fully, so I show below the relevant parts of my *mns partial menu. Could I impose on you to indicate the necessary changes
***MENUGROUP=ELECTRICAL
***POP1
[Y32.2(Imp.)]
[Y32.2 ELECTRICAL SYMBOLS]
[For Imperial Size Sheets]
[Set Parameters]^C^C_grid 0.4;_snap 0.2;_linetype;_l;drain,pilot,enclosure;fplines;;
[Previous Image Menu]^C^C$i=ELECTRICAL.*;
[Previous Symbol]^C^C_insert;;
[->Qwikpik]
[Battery]^C^C_insert 6el1x2 \;;\
[Bell]^C^C_insert 6el0y1 \;;\
[->&next]
[Motor Ser]^C^C_insert 6el5n \;;\
[Motor Shnt]^C^C_insert 6el5p \;;\
[Thrm'stat.NC]^C^C_insert 6el0j \;;\
[<-<-Transformer]^C^C_insert 6el1b \;;\
[Alarms/Indicators...]$i=ELECTRICAL.alarms1 i=ELECTRICAL.*
[->Basic Components]
[Resistors/Capacitors...]$i=ELECTRICAL.basics1 $i=ELECTRICAL.*
[<-Miscellaneous...]$i=ELECTRICAL.basics2 $i=ELECTRICAL.*
[->Circuit Protection]
[Single Pole...]$i=ELECTRICAL.prot1 $i=ELECTRICAL.*
[Two Pole...]$i=ELECTRICAL.prot2 $i=ELECTRICAL.*
[Three Pole...]$i=ELECTRICAL.prot3 $i=ELECTRICAL.*
***IMAGE
**ALARMS1
[ALARMS ]
[an60(iel0y1,Bell)]^C^C_insert 6el0y1 \;;\
[an60(iel0y2,Buzzer)]^C^C_insert 6el0y2 \;;\
[an60(iel0y3,Speaker)]^C^C_insert 6el0y3 \;;\
[an60(iel0y4,Speaker-Bidirec.)]^C^C_insert 6el0y4 \;;\
[an60(iel0y5,Bell-Single Strike)]^C^C_insert 6el0y5 \;;\
[an60(iel0y6,Microphone)]^C^C_insert 6el0y6 \;;\
[an60(iel0y7,Headphone)]^C^C_insert 6el0y7 \;;\
[an60(iel0y8,Headphone/Microphone)]^C^C_insert 6el0y8 \;;\
[an60(iel0x3,Siren)]^C^C_insert 6el0x3 \;;\
[an60(iel0x4,Horn)]^C^C_insert 6el0x4 \;;\
[an60(iel0x1,Signal Lamp)]^C^C_insert 6el0x1 \;;\
[an60(iel0x2,Signal Lamp-Flasher)]^C^C_insert 6el0x2 \;;\
[an60(iel4z1,Lamp)]^C^C_insert 6el4z1 \;;\
[an60(iel4z2,Neon-ac)]^C^C_insert 6el4z2 \;;\
[an60(iel4z3,Neon-dc)]^C^C_insert 6el4z3 \;;\
[an60(iel4z4,Flash Tube)]^C^C_insert 6el4z4 \;;\
[an60(iel4z5,Incandescent lamp)]^C^C_insert 6el4z5 \;;\
[an60(iel4z6,Fluorescent-Cold Cathode)]^C^C_insert 6el4z6 \;;\
[an60(iel4z7,Fluorescent)]^C^C_insert 6el4z7 \;;\
**BASICS1
[RESISTORS & CAPACITORS]
[ba60(iel1q,Resistor-Fixed)]^C^C_insert 6el1q \;;\
[ba60(iel1g,Resistor-Adjustable)]^C^C_insert 6el1g \;;\
[ba60(iel1p,Rheostat-Preset)]^C^C_insert 6el1p \;;\
[ba60(iel1m,Rheostat-Adjustable)]^C^C_insert 6el1m \;;\
[ba60(iel1r,Resistor-Preset)]^C^C_insert 6el1r \;;\
[ba60(iel1u,Resistor-Power-Fixed)]^C^C_insert 6el1u \;;\
[ba60(iel1n,Rheostat-Adjustable)]^C^C_insert 6el1n \;;\
[ba60(iel1d,Resistor-Rotary)]^C^C_insert 6el1d \;;\
[ba60(iel1j,Capacitor-Polarized)]^C^C_insert 6el1j \;;\
[ba60(iel1l,Capacitor-Polarized)]^C^C_insert 6el1l \;;\
[ba60(iel1k,Capacitor-Fixed)]^C^C_insert 6el1k \;;\
[ba60(iel1s,Capacitor-Variable)]^C^C_insert 6el1s \;;\
[iec61702(blank,-----------------)]
[iec61702(blank,OTHER SUB-MENUS)]
[ Miscell. Items...>]$i=ELECTRICAL.basics2 $i=ELECTRICAL.*
**BASICS2
[MISCELLANEOUS ITEMS]
[ba60(iel1v,Terminal/Connection)]^C^C_insert 6el1v \;;\
[ba60(iel1v1,Vertical Connection)]^C^C_insert 6el1v1 \;;\
[ba60(iel1v2,Horizontal Connection)]^C^C_insert 6el1v2 \;;\
[ba60(iel1w,Frame)]^C^C_insert 6el1w \;;\
[ba60(iel1x1,Cell)]^C^C_insert 6el1x1 \;;\
[ba60(iel1x2,Multi-Cell)]^C^C_insert 6el1x2 \;;\
[ba60(iel1w1,Ground)]^C^C_insert 6el1w1 \;;\
[ba60(iel1y,Fusible Link)]^C^C_insert 6el1y \;;\
[ba60(iel0t1,Safety Interlock-n.c.)]^C^C_insert 6el0t1 \;;\
[ba60(iel0t2,Safety Interlock-n.o.)]^C^C_insert 6el0t2 \;;\
[ba60(iel1z,Slip Ring)]^C^C_insert 6el1z \;;\
[ Resistors & Caps...>]$i=ELECTRICAL.basics1 $i=ELECTRICAL.*
