AutoLISP debugger for IntelliCAD
Posted: Mon Jan 12, 2009 10:48 am
Hi everyone.. new to this forum
old school MEP engineer (HVAC, fire protection, plumbing & Electrical)
(i.e. - old dog trying to learn new tricks)
I have several AutoLISP files that work in AutoCAD, but only a very few work in my IntelliCAD Pro 6.5 by DP Tech or my ProgeCAD 6.4 when I try them.
My understanding is AutoCAD had a built in LISP debugger to find LISP problems.
Is there a LISP debugger add-on or stand alone for IntelliCAD that will execute line-by-line or point me to the line of code causing the error?
The IntelliCAD command/status bar or F2 Text Window doesn't give me enough specifics... just something to the effect lisp loaded & then "null function".
Also, with AutoCAD using ARX & VLX, several add-on programs that work in AutoCAD won't work in my IntelliCAD versions. Only a few developers, that I have found, are currently writing MEP software to work with IntelliCAD.
What's in the future for IntelliCAD programming? will they stay with LISP, SDS & VBA or move to VB.net, Visual LISP.. What about OpenDCL which works with AutoCAD but does not support IntelliCAD?
Thanks for your comments..
