Hello,
Here is an example on how to extract the coordinates of a polyline:
Public Sub ShowLWPolylineCoordinates()
Dim doc As IntelliCAD.Document
Dim selEnt As IntelliCAD.entity
Dim pT1 As IntelliCAD.Point
Dim Ename As String
Set doc = IntelliCAD.ActiveDocument
doc.Utility.GetEntity selEnt, pT1, "Select a polyline: "
Ename = selEnt.EntityName
If Ename = "LightWeightPolyline" Then
   Dim selPL As IntelliCAD.LWPolyline
   Set selPL = selEnt
   Dim ptTmp As IntelliCAD.Point
   For Each ptTmp In selPL.Coordinates
      MsgBox ptTmp.x & "x" & ptTmp.y & "x" & ptTmp.z
   Next
End If
Hope this helps!
JCAMPOS
