I'm writing VBA for IntelliCAD 7.2 and have run into an interesting roadblock. I have been trying to update the textstring property of a selected entity with failure. When changing the textstring property of an entity, the code invokes an automation error. Upon adding an 'On Error Resume Next' handler, I discovered that while the first execution of the code results in the automation error, if the code is executed again on the same selection then it will work perfectly, updating the text in the ModelSpace to what is entered. Selecting a new entity to edit invokes the error, but again works the second, third, and forthcoming times that particular entity is selected. Below is the code, which I isolated to a single userform in a clean CommonProjects file for my tests:
Private Sub UpdTxtBtn_Click()
Dim PickObj As Object
Dim Txt As String
Dim Pt1 As IntelliCAD.Point
Me.Hide
ThisWorkspace.Application.ActiveDocument.Utility.GetEntity PickObj, Pt1, "Please select text in Model Space..."
Txt = InputBox("Enter the text you wish to edit the selected text to...", "New Text", "Sample Edit")
PickObj.TextString = Txt
PickObj.Update
Err.Clear
Me.Show
