F7 Grid
Posted: Mon Dec 07, 2015 3:15 pm
by mapcon col
I am new to Intellicad. I have loaded V8.1 to two PC's. On one I have set the startup so that the grid(F&) does not appear. On the other I cannot get it to hold that setting. Every time I open Intellicad the screen shows the grid.
I have also set F7 to off and saved the .dwt file but still no good. Can anyone help?
Posted: Mon Dec 21, 2015 6:12 pm
by CMS Inc
Such GRID (ON/OFF) default settings are saved at icad.dwt file, typically located at C:\Program Files\CMS\CMS IntelliCAD 8.1 Premium Edition Plus\Templates\icad.dwt
You need to review the TEMPLATES path at the program OPTIONS . Use command: OPTIONS , _CONFIG, Ribbon tools tab > Options... or use the traditional TOOLS > Options... dropdown menu
F7 Grid
Posted: Mon Dec 21, 2015 9:27 pm
by mapcon col
CMS Inc wrote:Such GRID (ON/OFF) default settings are saved at icad.dwt file, typically located at C:\Program Files\CMS\CMS IntelliCAD 8.1 Premium Edition Plus\Templates\icad.dwt
I have set the icad.dwt and drawing1.dwg to both not show grid and saved them. Still get grid showing every time I first start Intellicad.
Posted: Tue Jan 19, 2016 11:19 am
by efernal
Put the line above in Icad.lsp
(SETVAR "GRIDMODE" 0)
Posted: Tue Jan 19, 2016 3:40 pm
by mapcon col
Thanks, but I cannot find any.lsp files.
I have done a search but none appear on anywhere.
Posted: Wed Jan 20, 2016 7:07 am
by efernal
Just type the line bellow and press enter
(STARTAPP "NOTEPAD.EXE" (FINDFILE "ICAD.LSP"))
Posted: Wed Jan 27, 2016 7:52 pm
by CMS Inc
You can also create an icad.lsp text file using MS Notepad. Make sure to rename the *.txt file extension to *.lsp
Then, place the file at:
CMS IntelliCAD 8.1 PE+:
CMS IntelliCAD 8.1 PE:
Editing the content of such lisp file is also a way to auto-load lisp routines using LOAD instruction as:
(load "C:\\lisp routines folders path here\\file name.lsp")
Use "\\" between each folder along the folders path.
Posted: Mon Feb 01, 2016 9:36 am
by tharinton
I am also new to CMS IntelliCAD and I am evaluating 8.1 for my engineering company. I am having the same problem with the grid - no matter what I do I can't get it to stay off. Each time I open CMS IntelliCAD it appears and I have to turn it off. Quite bothersome. Is this a known issue or a bug?
