Double clicking over a *.dwg file
Posted: Thu Apr 20, 2017 5:58 am
by CMS Inc
Some operating systems that run multiple applications able to run *.dwg files may face issues to properly pop&run CMS IntelliCAD by direct DWG file double clicking located at a Windows folder or Windows desktop.
Make sure you to uninstall CMS IntelliCAD , reboot the system and reinstall CMS IntelliCAD again.
Then, right mouse click on top of a dwg file and select > properties > General tab > Press "change" button > click "more apps" > browse to the end of all options and select "Look for another app on this PC". At this point browse for icad.exe at software edition version located, by default, at C:\Program Files\CMS
Re: Double clicking over a *.dwg file
Posted: Fri May 19, 2017 1:08 am
When I try using the 'double click' method for opening a drawing I receive an error message:
"There was a problem while sending the command to the program"
Intellicad opens in the background, with no drawing loaded, and if I double click on the drawing again it will then open in Intellicad.
Thoughts?
Posted: Sat Jul 29, 2017 1:30 am
by gbdesign
This is a very late reply to the original post by SteveN, but I had exactly the same problem a few months ago. I was able to solve this eventually, as I discovered that there was an entry in my Windows registry (using Win7 64 bit) which referred to an older version of Intellicad (8.1). Even though I had removed v8.1 last year, the registry key was still there. After I deleted the key and re-installed Intellicad v8.3, the problem was solved.
I'm afraid I don't recall the exact registry key - found it by searching for any keys with "DWG'.
Good luck.
Graeme
Posted: Tue Aug 29, 2017 7:19 pm
by gbdesign
Well, after upgrading to Intellicad 8.4, I have once again got the problem of the error message "There was a problem while sending the command to the program". After a bit of internet searching I have discovered how to solve this for Intellicad, which requires a change to the windows registry. Note I am using windows 7 64 bit:
Go to the registry key:
HKEY_CLASSES_ROOT\Icad.Drawing\shell\open\command
On my system the default value was:
C:\Program Files\CMS\IntelliCAD 8.4 Premium Edition Plus\icad.exe /dde
Change this to read as follows (note quotation marks):
"C:\Program Files\CMS\IntelliCAD 8.4 Premium Edition Plus\icad.exe" "%1"
Go to the key:
HKEY_CLASSES_ROOT\Icad.Drawing\shell\open\ddeexec
Delete the default value (which should be Open("%1") ).
Everything is now working fine on my system.
