Curve.GetGeCurve throws "Operation is not valid due to the current state of the object"
Posted: Thu Jun 11, 2020 4:00 pm
Hi, I am trying to get the Curve3d of a Curve without success. Here is a simple command. If I select a curve and run the command I get System.InvalidOperationException.
How can I make this work?
public static void Execute()
var document = Application.DocumentManager.MdiActiveDocument;
var database = document.Database;
var selection = CommandHelper.GetOrAskSelection(document);
var selectionSet = selection.Value;
using (var transaction = database.TransactionManager.StartTransaction())
var curves = new List<Curve3d>();
foreach (var id in selectionSet.GetObjectIds())
var entity = (Entity) transaction.GetObject(id, OpenMode.ForRead);
if (entity is Curve curve)
curves.Add(curve.GetGeCurve()); <-- error here
