Page 1 of 2
OSNAP / Rastreamento polar
Posted: Mon Nov 23, 2020 11:58 am
by DenisSilveira
Como utilizar/habilitar o OSNAP em comandos criados através do VBNET.
Minhas ferramentas não funcionam com OSNAP/ESNAP.
O rastreamento polar também fica desabilitado.
O uso das teclas F10/F3 ou opções na barra de ferramentas não habilitam OSNAP/ESNAP, embora seja visível na barra de status que estão habilitados, na tela não selecionam.
Re: OSNAP / Rastreamento polar
Posted: Sun Nov 29, 2020 4:38 pm
by CMS Inc
Please post your support queries in English.
Posted: Wed Dec 02, 2020 9:10 am
Not sure what you mean, but please refer this for turn ON/OFF OSNAP: viewtopic.php?f=3&t=1819&sid=fc6bcb1de2 ... 647ddcb76a
Posted: Wed Dec 02, 2020 9:23 am
by DenisSilveira
QuanNguyen wrote: ↑
Sorry about that.
I am trying to use OSNAP/Polar inside a VBNET command.
When I run the command, the OSNAP/ESNAp os objects does not is available.
OSNAP/ESNAP is available only in native commands.
Or, there is some variable to set when command begins ... or some SYSTEMVAR is missing inside command.
I tryied examples in package os CMS but nothing difrent or new ... I really believe I am missing somethig ...
Posted: Wed Dec 02, 2020 9:25 am
by DenisSilveira
DenisSilveira wrote: ↑
QuanNguyen wrote: ↑
Sorry about that.
PS.: I also tryied to set SYSTEMVAR("OSNAP") but it´s not usefull ... simply doens't select object snap in any option.
Posted: Wed Dec 02, 2020 5:35 pm
Can you attach some code here?
Posted: Thu Dec 03, 2020 1:31 pm
by DenisSilveira
This lines code is button inside a uc Form to click e run this code:
        Dim doc As Document = acApp.DocumentManager.MdiActiveDocument
        Dim db As Teigha.DatabaseServices.Database = doc.Database
        Dim ed As Editor = doc.Editor
        Try
            Using acLock As DocumentLock = doc.LockDocument()
                    Dim P As New clsPerfiltabela(cbPerfil.SelectedValue)
                    Dim ltr As LayerTableRecord = CType(tr.GetObject(db.Clayer, teigha.DatabaseServices.OpenMode.ForRead), LayerTableRecord)
                    P.LayerMesa = LayMesa
                    P.LayerAlma = LayAlma
                    P.LayrCentro = LayCentro
                    P.offset = tbOffset.Text
                    Dim ppo As New PromptPointOptions("Ponto inicial>")
                    ppo.UseBasePoint = False
                    Dim ppr As PromptPointResult = ed.GetPoint(ppo)
                    If ppr.Status = PromptStatus.Cancel Then Exit Sub
                    Do
                        ppo = New PromptPointOptions("Próximo>")
                        ppo.UseBasePoint = True
                        ppo.BasePoint = ppr.Value
                        ppo.LimitsChecked = False
                        P.m_pt1 = ppr.Value
                        ppr = ed.GetPoint(ppo)
                        If Not ppr.Status = PromptStatus.Cancel Then
                            P.m_pt2 = ppr.Value
                            P.m_pto_base = P.m_pt1
                            P.DesenharPlanta()
                    Loop Until ppr.Status = PromptStatus.Cancel
                    tr.Commit()
                End Using
            End Using
        Catch ex As System.Exception
            MsgBox(ex.Message, vbCritical)
        Finally
        End Try
This lines code is for the classe above:
Public Sub DesenharPlanta()
        Dim doc As IntelliCAD.ApplicationServices.Document = Core.Application.DocumentManager.MdiActiveDocument
        Dim u As New Utilidade
        Dim col As New List(Of ObjectId)
        Dim colPerfil As New List(Of ObjectId)
        ''doc.Window.Focus()
        'ObterPontos()
        Try
                    Dim acBlkTbl As BlockTable = tr.GetObject(db.BlockTableId, Teigha.DatabaseServices.OpenMode.ForRead)
                    Dim acBlkTblRec As BlockTableRecord = tr.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), Teigha.DatabaseServices.OpenMode.ForWrite)
                    If Not IsNothing(m_pt1) AndAlso Not IsNothing(m_pt2) Then
                        Dim ptsMesa As New Point3dCollection
                        Dim ptsMesa2 As New Point3dCollection
                        Dim ptsAlma As New Point3dCollection
                        Dim ptsAlma2 As New Point3dCollection
                        Dim ptsHatch As New Point3dCollection
                        Dim ml As Mline = New Mline()
                        ml.SetDatabaseDefaults()
                        Dim PLinhaMesa As New Polyline
                        PLinhaMesa.SetDatabaseDefaults()
                        Dim PLinhaMesa2 As New Polyline
                        PLinhaMesa2.SetDatabaseDefaults()
                        Dim PLinhaAlma As New Polyline
                        PLinhaAlma.SetDatabaseDefaults()
                        Dim PLinhaAlma2 As New Polyline
                        PLinhaAlma2.SetDatabaseDefaults()
                        Dim PLinhaHatch As New Polyline
                        PLinhaHatch.SetDatabaseDefaults()
                        Dim LinhaDeCentro As Line = New Line(m_pt1, m_pt2)
                        LinhaDeCentro.SetDatabaseDefaults()
                        Dim acLineTypTbl As LinetypeTable
                        Dim sLineTypName As String
                        Select Case Tipo
#Region "trilho"
                            Case cTiposDePerfil.Trilho
                                CreateMLineStyleW(Descricao, bf, tw)
                                ml.Style = db.CmlstyleID
                                ml.Normal = Vector3d.ZAxis
                                ml.Justification = MlineJustification.Zero
                                ml.AppendSegment(m_pt1)
                                ml.AppendSegment(m_pt2)
                                Dim btr As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, Teigha.DatabaseServices.OpenMode.ForWrite), BlockTableRecord)
                                btr.AppendEntity(ml)
                                tr.AddNewlyCreatedDBObject(ml, True)
                                tr.TransactionManager.QueueForGraphicsFlush()
                                col.Add(ml.ObjectId)
                                colPerfil.Add(ml.ObjectId)
#End Region
#Region "Redondos"
                            Case cTiposDePerfil.Redondos
#Region "Revisão 10/1/19"
                                CreateMLineStyleRedondos(Descricao, bf)
#End Region
#Region "Antigo"
                        'Dim objId As ObjectId = utilidade.addLine(m_pt1, m_pt2)
                        'col.Add(objId)
                        ''obter o angulo
                        'LinhaDeCentro = tr.GetObject(objId, teigha.DatabaseServices.OpenMode.ForRead)
                        'Dim Ang As Double = LinhaDeCentro.Angle
                        'Dim pt3 As Point3d = utilidade.GetPointAtDist(m_pt1, Math.PI * 3 / 2 + Ang, bf / 2)
                        'Dim pt4 As Point3d = utilidade.GetPointAtDist(m_pt2, Math.PI * 3 / 2 + Ang, bf / 2)
                        'ptsMesa.Add(pt3)
                        'ptsMesa.Add(pt4)
                        'pt3 = utilidade.GetPointAtDist(m_pt1, Math.PI / 2 + Ang, bf / 2)
                        'pt4 = utilidade.GetPointAtDist(m_pt2, Math.PI / 2 + Ang, bf / 2)
                        'ptsMesa.Add(pt4)
                        'ptsMesa.Add(pt3)
                        'ptsAlma2.Add(pt3)
                        'ptsAlma2.Add(pt4)
                        'acBlkTblRec.AppendEntity(PLinhaMesa)
                        'tr.AddNewlyCreatedDBObject(PLinhaMesa, True)
                        'Dim i As Integer = 0
                        'For Each pt As Point3d In ptsMesa
                        '    PLinhaMesa.AddVertexAt(i, New Point2d(pt.X, pt.Y), 0, 0, 0)
                        '    i += 1
                        'Next
                        'PLinhaMesa.Closed = True
                        'PLinhaMesa.Layer = LayerMesa
                        'col.Add(PLinhaMesa.ObjectId)
#End Region
#End Region
#Region "Chatos"
                            Case cTiposDePerfil.Chatos
                                CreateMLineStyleChatos(Descricao, bf)
#End Region
#End Region
#Region "UDC duplo"
                            Case cTiposDePerfil.UDC_Duplo
                                CreateMLineStyleUDCDuplo(Descricao, bf, tw)
#End Region
#End Region
#Region "CE Composto"
                            Case cTiposDePerfil.CE_COMPOSTO
                                Dim objId As ObjectId = Utilidade.addLine(m_pt1, m_pt2)
                                col.Add(objId)
                                colPerfil.Add(objId)
                                'obter o angulo
#Region "LADO ESQUERDO"
                                LinhaDeCentro = tr.GetObject(objId, Teigha.DatabaseServices.OpenMode.ForRead)
                                Dim pt3 As Point3d '= utilidade.GetPointAtDist(m_pt1, Math.PI / 2 + Ang, bf)
                                Dim pt4 As Point3d '= utilidade.GetPointAtDist(m_pt2, Math.PI / 2 + Ang, bf)
                                ptsMesa.Add(m_pt1)
                                ptsMesa.Add(m_pt2)
                                pt3 = Utilidade.GetPointAtDist(m_pt1, Math.PI / 2 + Ang, bf)
                                pt4 = Utilidade.GetPointAtDist(m_pt2, Math.PI / 2 + Ang, bf)
                                ptsMesa.Add(pt4)
                                ptsMesa.Add(pt3)
                                pt3 = Utilidade.GetPointAtDist(m_pt1, Math.PI / 2 + Ang, tw)
                                pt4 = Utilidade.GetPointAtDist(m_pt2, Math.PI / 2 + Ang, tw)
                                ptsAlma.Add(pt3)
                                ptsAlma.Add(pt4)
                                pt3 = Utilidade.GetPointAtDist(m_pt1, Math.PI / 2 + Ang, bf - tw)
                                pt4 = Utilidade.GetPointAtDist(m_pt2, Math.PI / 2 + Ang, bf - tw)
                                ptsAlma.Add(pt4)
                                ptsAlma.Add(pt3)
                                    i += 1
                                Next
                                colPerfil.Add(PLinhaMesa.ObjectId)
                                acBlkTblRec.AppendEntity(PLinhaAlma)
                                tr.AddNewlyCreatedDBObject(PLinhaAlma, True)
                                i = 0
                                For Each pt As Point3d In ptsAlma
                                    PLinhaAlma.AddVertexAt(i, New Point2d(pt.X, pt.Y), 0, 0, 0)
                                    i += 1
                                Next
                                PLinhaAlma.Closed = True
                                PLinhaAlma.Layer = LayerAlma
                                col.Add(PLinhaAlma.ObjectId)
                                colPerfil.Add(PLinhaAlma.ObjectId)
#End Region
#Region "LADO DIREITO"
                                ptsMesa = New Point3dCollection
                                ptsMesa.Add(m_pt1)
                                ptsMesa.Add(m_pt2)
                                pt3 = Utilidade.GetPointAtDist(m_pt1, Math.PI * 3 / 2 + Ang, bf)
                                pt4 = Utilidade.GetPointAtDist(m_pt2, Math.PI * 3 / 2 + Ang, bf)
                                ptsMesa.Add(pt4)
                                ptsMesa.Add(pt3)
                                pt3 = Utilidade.GetPointAtDist(m_pt1, Math.PI * 3 / 2 + Ang, tw)
                                pt4 = Utilidade.GetPointAtDist(m_pt2, Math.PI * 3 / 2 + Ang, tw)
                                ptsAlma = New Point3dCollection
                                ptsAlma.Add(pt3)
                                ptsAlma.Add(pt4)
                                pt3 = Utilidade.GetPointAtDist(m_pt1, Math.PI * 3 / 2 + Ang, bf - tw)
                                pt4 = Utilidade.GetPointAtDist(m_pt2, Math.PI * 3 / 2 + Ang, bf - tw)
                                ptsAlma.Add(pt4)
                                ptsAlma.Add(pt3)
                                PLinhaMesa = New Polyline
                                i = 0
                                    i += 1
                                Next
                                PLinhaAlma = New Polyline
                                i = 0
                                    i += 1
                                Next
#End Region
#End Region
#Region "CLaminado"
#End Region
#Region "UDC rigido, UE, Eu Duplo"
#End Region
#Region "UDC"
                            Case cTiposDePerfil.UDC, cTiposDePerfil.UDCRigido, cTiposDePerfil.UE, cTiposDePerfil.UE_duplo,
                         cTiposDePerfil.Chapeu, cTiposDePerfil.Z, cTiposDePerfil.Ze
                                CreateMLineStyleUDC_Planta(Descricao, bf, tf)
#End Region
#End Region
#Region "Tubo Retangular"
                            Case cTiposDePerfil.TuboRetangular, cTiposDePerfil.TuboCircular, cTiposDePerfil.TuboQuadrado, cTiposDePerfil.TuboAL
                                CreateMLineStyleTubos(Descricao, bf, tf)
#End Region
#End Region
#Region "Tubo Quadrado"
#End Region
#Region "Tubo Circular"
#End Region
#Region "Cantoneira"
                            Case cTiposDePerfil.Cantoneira, cTiposDePerfil.CantoneiraDesigual, cTiposDePerfil.CantoneiraAL, cTiposDePerfil.CantoneiraDupla
                                CreateMLineStyleCantoneira(Descricao, bf, tw)
#End Region
#Region "W, Cs, CVS, VS"
                            Case cTiposDePerfil.VigaW, cTiposDePerfil.VS, cTiposDePerfil.CVS, cTiposDePerfil.CS
                                CreateMLineStyleW(Descricao, bw, tw)
#End Region
                        '' Open the Linetype table for read
#End Region
#Region "Chapeu"
#End Region
#Region "Z"
                            Case cTiposDePerfil.Z
#End Region
#Region "Ze"
                            Case cTiposDePerfil.Ze
#End Region
                            Case cTiposDePerfil.Trelica
#Region "Treliça"
                                Dim idAux As Integer = IdBanzo
                                Dim Per As New clsPerfiltabela(idAux)
                                CreateMLineStyleCantoneira(Per.Descricao, Per.bf, Per.tw)
                                Dim LineSeg As New Line(m_pt2, m_pt1)
                                ml.AppendSegment(Utilidade.GetPointAtDist(m_pt2, Math.PI / 2 + LineSeg.Angle, Espacador / 2 + Per.bf / 2))
                                ml.AppendSegment(Utilidade.GetPointAtDist(m_pt1, Math.PI / 2 + LineSeg.Angle, Espacador / 2 + Per.bf / 2))
                                ml = New Mline
                                ml.AppendSegment(Utilidade.GetPointAtDist(m_pt1, Math.PI / 2 * 3 + LineSeg.Angle, Espacador / 2 + Per.bf / 2))
                                ml.AppendSegment(Utilidade.GetPointAtDist(m_pt2, Math.PI / 2 * 3 + LineSeg.Angle, Espacador / 2 + Per.bf / 2))
#End Region
#Region "Joist"
                            Case cTiposDePerfil.Joist
                                Dim Banzo As New clsPerfiltabela(idAux)
                                Dim Diagonal As New clsPerfiltabela(IdDiagonal)
                                CreateMLineStyleCantoneira(Diagonal.Descricao, Diagonal.bf, Diagonal.tw)
                                Dim StyleDiagonal As ObjectId = db.CmlstyleID
                                CreateMLineStyleCantoneira(Banzo.Descricao, Banzo.bf, Banzo.tw)
                                Dim StyleBanzo As ObjectId = db.CmlstyleID
                                ml.Style = StyleBanzo
                                Dim LineSeg As New Line(m_pt1, m_pt2)
                                m_pt2 = New Point3d(m_pt1.X + LineSeg.Length, m_pt1.Y, m_pt1.Z)
                                ml.AppendSegment(Utilidade.GetPointAtDist(m_pt1, Math.PI / 2 * 3, (Banzo.bf / 2 + Espacador / 2)))
                                ml.AppendSegment(Utilidade.GetPointAtDist(m_pt2, Math.PI / 2 * 3, (Banzo.bf / 2 + Espacador / 2)))
                                Dim XP As New XPerfil
                                XP.Entity = ml
                                XP.ID = Banzo.Id
                                XP.Commit()
                                ml = New Mline
                                ml.AppendSegment(Utilidade.GetPointAtDist(m_pt2, Math.PI / 2, (Banzo.bf / 2 + Espacador / 2)))
                                ml.AppendSegment(Utilidade.GetPointAtDist(m_pt1, Math.PI / 2, (Banzo.bf / 2 + Espacador / 2)))
                                XP = New XPerfil
                                XP.Entity = ml
                                XP.ID = Banzo.Id
                                XP.Commit()
                                Dim pt1 As New Point3d(m_pt1.X + Banzo.bf / 2, m_pt1.Y - (Banzo.bf + Espacador / 2), m_pt1.Z)
                                Dim pt2 As New Point3d(m_pt1.X + (Banzo.bf + Espacador) + Banzo.bf / 2, m_pt1.Y + (Banzo.bf + Espacador / 2), m_pt1.Z)
                                Dim contador As Integer = Math.Floor(LineSeg.Length / (Banzo.bf + Espacador))
                                For i As Integer = 1 To contador
                                    ml = New Mline
                                    ml.Style = StyleDiagonal
                                    LineSeg = New Line(pt1, pt2)
                                    ml.AppendSegment(Utilidade.GetPointAtDist(pt2, LineSeg.Angle + Math.PI, Banzo.bf * 2 ^ 0.5))
                                    ml.AppendSegment(Utilidade.GetPointAtDist(pt1, LineSeg.Angle, Banzo.bf * 2 ^ 0.5))
                                    XP = New XPerfil
                                    XP.Entity = ml
                                    XP.ID = Diagonal.Id
                                    XP.Commit()
                                    ml = New Mline
                                    ml.AppendSegment(New Point3d(pt1.X, pt2.Y, pt1.Z))
                                    ml.AppendSegment(pt1)
                                    XP = New XPerfil
                                    XP.Entity = ml
                                    XP.ID = Diagonal.Id
                                    XP.Commit()
                                    pt1 = New Point3d(pt1.X + (Banzo.bf + Espacador), pt1.Y, pt1.Z)
                                    pt2 = New Point3d(pt2.X + (Banzo.bf + Espacador), pt2.Y, pt2.Z)
                                Next
                                ' última diagonal e montante
                                pt2 = New Point3d(m_pt2.X, pt2.Y, pt2.Z)
                                'diagonal
                                ml = New Mline
                                XP = New XPerfil
                                XP.Entity = ml
                                XP.ID = Diagonal.Id
                                XP.Commit()
                                ' montante
                                ml = New Mline
                                LineSeg = New Line(pt1, New Point3d(pt1.X, pt2.Y, pt2.Z))
                                XP = New XPerfil
                                XP.Entity = ml
                                XP.ID = Diagonal.Id
                                XP.Commit()
                                'montante final
                                ml = New Mline
                                ml.AppendSegment(New Point3d(pt2.X - Banzo.bf / 2, pt1.Y, pt1.Z))
                                ml.AppendSegment(New Point3d(pt2.X - Banzo.bf / 2, pt2.Y, pt2.Z))
                                XP = New XPerfil
                                XP.Entity = ml
                                XP.ID = Diagonal.Id
                                XP.Commit()
#End Region
                        End Select
                        sLineTypName = Linhas.Center
                        acLineTypTbl = tr.GetObject(IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.LinetypeTableId,
                        Dim LineTypesPath As String = IntelliCAD.ApplicationServices.Application.GetSystemVariable("LINETYPESPATH")
                        Dim path As String = String.Format("{0}\{1}", LineTypesPath, "Icad.lin")
                        If acLineTypTbl.Has(sLineTypName) = False Then
                            '' Load the Center Linetype
                            IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.LoadLineTypeFile(sLineTypName, path)
                        sLineTypName = Linhas.Dashed
#Region "xdata"
                        Utilidade.AddRegAppTableRecord(Aplicativos.Grelha.Perfil)
                        Dim rb As New ResultBuffer
                        Dim rb2 As ResultBuffer = New ResultBuffer
                        rb2.Add(New TypedValue(DxfCode.ExtendedDataAsciiString, vId.ToString(New CultureInfo("pt-br"))))
                        rb.Add(New TypedValue(DxfCode.ExtendedDataRegAppName, Aplicativos.Grelha.Perfil))
                        rb.Add(New TypedValue(DxfCode.ExtendedDataAsciiString, vId.ToString(New CultureInfo("pt-br"))))
                        ml.XData = rb
#End Region
#Region "HATCH"
#End Region
                        Colect = New ObjectIdCollection
                        For Each c As ObjectId In colPerfil
                            Colect.Add(c)
                            XP.Entity = c.GetObject(Teigha.DatabaseServices.OpenMode.ForWrite)
                            XP.ID = vId
                            XP.Commit()
                            Dim XV As New XVista
                            XV.Entity = XP.Entity
                            XV.Vista = Vistas.Planta
                            XV.commit()
                        Next
                        Dim baseWcs As Point3d = m_pto_base.TransformBy(ed.CurrentUserCoordinateSystem)
                        Dim jigger As New AcadNetAddinCS.MoveRotationScaleJig(m_pto_base)
                        If isJigger Then
                            For Each id As ObjectId In col
                                Dim ent As Entity = DirectCast(tr.GetObject(id, Teigha.DatabaseServices.OpenMode.ForWrite), Entity)
                                ent.XData = Xdata()
                                jigger.AddEntity(ent)
                            Next
                            If jigger.Jig() Then
                                jigger.TransformEntities()
                        m_angle = LinhaDeCentro.Angle
                        ptsMesa.Dispose()
                        ptsMesa2.Dispose()
                        ptsAlma.Dispose()
                        ptsAlma2.Dispose()
                        ptsHatch.Dispose()
                    tr.Commit()
                End Using
            End Using
            MsgBox(String.Format("Erro: {0} {1} {2}", ex.Message, ex.Source, ex.StackTrace), MsgBoxStyle.Critical, "Erro de seleção de vigas")
        Finally
        End Try
Posted: Thu Dec 03, 2020 1:35 pm
by DenisSilveira
Even when we run a simple line draw with two editor.getpoint() we cannot select snap grips.
Objects snaps is not available to select when Editor.Getpoint is called.
In other hand, using BasePoint in PromptPointOption second call, after we had first call, the rubber line is not attached to the right point (the last beeing selected).
It´s quietly complicated to explain, but in INTELLICAD CMS 10 does not occur, but in ICMS 9 occurs.
ok.
Posted: Fri Dec 04, 2020 6:53 pm
Please refer to this simple code, the OSNAP/ORTHO work as it is.
    <CommandMethod("lineVBNet")>
    Public Sub lineVBNet()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Try
                    Dim bt As BlockTable = CType(tr.GetObject(doc.Database.BlockTableId, OpenMode.ForRead), BlockTable)
                    Dim btr As BlockTableRecord = CType(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
                    Dim startPt As Point3d
                    Dim endPt As Point3d
                    Dim ppo As New PromptPointOptions("Start point>")
                    startPt = ppr.Value
                    Do
                        ppo = New PromptPointOptions("Next point>")
                        ppo.BasePoint = startPt
                            endPt = ppr.Value
                            Dim line As Line = New Line(startPt, endPt)
                            btr.AppendEntity(line)
                            tr.AddNewlyCreatedDBObject(line, True)
                            'line.RecordGraphicsModified(True)
                            ed.Regen()
                            startPt = endPt
                    tr.Commit()
                End Using
            End Using
        Finally
        End Try
Posted: Sat Dec 05, 2020 4:12 pm
by DenisSilveira
Simply doesn't work.
see my Drawing Settings - snap
Posted: Sat Dec 05, 2020 4:16 pm
by DenisSilveira
I am desperate.
All of my commands in Acad is not working properly because depends of snap many times.
I bellieve there is some missing config anyway ...
May I need to explain that native commands like "line" (for simple) shows the grips for snaps defined in my config.
But commands called inside my linecodes doesn't. This makes me believ there is something ocurring during the interval time to call command and code to run, because object in window seems to be invisible.
Posted: Sat Dec 05, 2020 4:35 pm
by DenisSilveira
Just In time.
I tested your linecodes inside completly new app and works !!!
I need to find where is the bug ...
Posted: Sat Dec 05, 2020 5:04 pm
Yes, please double check your code.
Posted: Sun Dec 06, 2020 3:11 pm
by DenisSilveira
I had tryied many options. I descovered that calling <CommandMethod> directly is usefull.
When I call lineVbNet by form button or form menu the snaps is not working.
Calling CommandMethod goes directly to the window.
Calling by button or menu I need a first click to select the window and it's not also snaps working.
Keep going ... any sugestions are welcome.
Posted: Sun Dec 06, 2020 3:35 pm
by DenisSilveira
        Dim doc As IntelliCAD.ApplicationServices.Document = IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Try
Works
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
       lineVBNet()
       End sub
Does not work.
