How to access and set loft settings
Posted: Thu Jan 28, 2021 4:10 am
Hi
I'm in the middle of a routine where I am creating a 'concentric Reducer' but I am struggling to access the 'settings' dialogue for the 'loft' command.
Here is the dialogue box.
I want to change the 'Normal to' to 'Start & End'
I can't see a way to change this via the command line?
Steve
Re: How to access and set lof settings
Posted: Thu Jan 28, 2021 5:55 am
I have found the solution:
(setvar "LOFTNORMALS" 4)
So now to my next problem.
How can I insert a local variable into this statement ?:
(setq spt3 (strcat "0" "," "0" "," "200"))
I want to change the value 200 to the variable ERLENGTH.
I have tried:
(setq spt3 (strcat "0" "," "0" "," erlength))
This code works with the value 200 in place.
(defun DRAW_ER ( / spt1 spt2 ENT1 ENT2 ENT3 ENT4 ENT5 ENT6 EROD1 ERID1 EROD2 ERID2 ERLENGTH )
		(setq EROD1 N6)
		(setq ERID1 N9).
		(setq EROD2 N3)
		(setq ERID2 N10)
		(setq ERLENGTH N1)
 (if (and (setq spt1 (getpoint "\nSpecify Start point of Reducer"))
          (setq spt2 (getpoint "\nSpecify Direction of Reducer"))
	  (setq spt3 (strcat "0" "," "0" "," "200"))					;200 WAS ERLENGTH
     ) ;end of AND
      (progn
    (command "ucs" "ZA" spt1 spt2)
	(command "circle" "0,0,0" "d" erod1)		;take OD from dim file
		(setq ENT1 (entlast))
	(command "circle" "0,0,0" "d" erid1)		;take ID from dim file
		(setq ENT2 (entlast))
	(command "circle" spt3 "d" erod2)			;take OD from dim file
		(setq ENT3 (entlast))
	(command "circle" spt3 "d" erid2)			;take ID from dim file
		(setq ENT4 (entlast))
;												; setvar LOFTNORMALS 1  set this to 4
		(setvar "LOFTNORMALS" 4)				; this works on command line
	(command "loft" ENT1 "" ENT3 "" "")
		(setq ENT5 (entlast))
	(command "_loft" ENT2 "" ENT4 "" "")
		(setq ENT6 (entlast))
  	(command "subtract" ENT5 "" ENT6 "")
   	(command "ucs" "_P")
		(setvar "LOFTNORMALS" 1)
    ) ;_ end of progn
   )  ;_ end of IF
) ;end DRAW_ER
Steve
Re: How to access and set loft settings
Posted: Sat Jan 30, 2021 10:02 am
All sorted.
Changed this:
To this:
(setq spt3 (strcat "0" "," "0" "," (rtos erlength))
Steve
Posted: Mon Feb 01, 2021 12:22 am
You also can use:
(setq spt3 (list 0 0 erlength))
insteaf of "(setq spt3 (strcat "0" "," "0" "," (rtos erlength))"
Posted: Mon Feb 01, 2021 1:56 am
Thanks Quan, another way :)
I try to post updates if I find a solution in case someone comes along later.
Steve
