Plotting Problems
We did a complete drawing in Intellicad 4Pe. It was then opened in AutoCad 2000 and then saved subsequently in AutoCad 2000. This drawing when plotted through the assistance tool box of the wide format plotter 'OCE 9600' gives a print-out of only 1"x1", irespective of the drawing size (A, B,C,..etc). Plotting through this plotter does not require the *.dwg file to be opened as this plotter has its own utility.
If the same drawing is done totally in AutoCad 2000 and plotted through the same facility of 'OCE 9600', one does not face any problem at all.
Can this problem be rectified?
