Problem With IntelliCAD
Posted: Wed Nov 05, 2003 8:27 pm
Does anybody give me some advise regarding this Software?
1. Autosnap does not meet and pek end to end point.
2. Illegal operation.. When you load to much drawing to this software. Unlike to Autocad.
3. Copy drawing using command CTL+C. It does not have a base point where will you pick the drawing. and then when you paste it to another drawings it just paste it does not have a command question where will you put the drawing.
4. IntelliCAD is very slow compare to autoCAD. I thought the speed of this software is much faster than autoCAD because it does not have to much graphics loaded.
5. Printing- It gain to much space on both side.even when to window it
6. Dimension-Even when you configure the dimesion setting and then you close the IntelliCAD the default dim style will turn back. You will always configure the dimension when you open it. same as the text and bigfont style...
7. It does not support per user usage on windows 2000.. When another user try to use the intellicad the software doesnt work instead you will install it again and again.
8. It does not have a latest manual of V4. only IntelliCAD 2000 manual.
Still hoping to Improve you software.. Although it is cheeper our production begin to slow down.
Ronald
Ronald
