3D Polyline in IntelliCAD PE v3.1 2001
Hello, all,
For the longest time, I thought I was unable to use this AutoCAD command in IntelliCAD PE v3.1 2001. It is not in the Insert - 3D entities command bar. Nor is it discussed in the IntelliCAD 2001 users manual.
However, I did finally stumble across it in the IntelliCAD 2001 Help Index:
3D Polyline
Keyboard: 3DPOLY
Alias: 3P
Draws a three-dimensional polyline with straight segments. Although the 3D Polyline command does not have as many options as the Polyline command, you can apply editing changes, such as splining, with the Edit Polyline command after the three-dimensional polyline is drawn.
Wow, I need this in a drawing I am making.
Does anyone know how I can put this up in the command bar, so I do not have to keypunch it everytime I need it?
What other entities are not up there?
3D Polyline is available but not in the Insert - 3D Entities submenu
See in the IntelliCAD Help Index
Menu Item command
for information on how to put this up there.
