  4. VBA, . NET & IRX
Visual Studio NOT Debug Icad R14.1
  4. VBA, . NET & IRX
DenisSilveira
DenisSilveira
Sun May 24, 2020 8:22 am
#1 by DenisSilveira
After loading manuallly Icad process VisualStudio does not debug it.
Is ther anything I am missing ??
  • Sun Apr 12, 2026 12:22 pm
QuanNguyen
Sat Nov 09, 2019 6:50 pm
Re: Visual Studio NOT Debug Icad R14.1
#2 by QuanNguyen
DenisSilveira wrote: ↑
Please follow this instruction: viewtopic.php?p=12968#p12968
In the other case, please attach the project here if you don't mind.
Regards.
  • Sun Apr 12, 2026 7:37 pm
DenisSilveira
DenisSilveira
#3 by DenisSilveira
I followed these instructions, and the fact is the VS loads ICad but don´t debu, is running normally but not stopping breakpoints or errors
  • Mon Apr 13, 2026 9:16 am
QuanNguyen
#4 by QuanNguyen
Your project uses .NET Framework (4.x) or .NET 8?
  • Mon Apr 13, 2026 6:11 pm
DenisSilveira
DenisSilveira
#5 by DenisSilveira
version 14.1.479.171147.PE+.VC17.x64.CMS141
not debbuging, can´t find CLR.dll to VS debug
  • Mon Apr 13, 2026 6:18 pm
DenisSilveira
DenisSilveira
#6 by DenisSilveira
after hundreds of tests OpenAI says it's a Icad limitation for V14
  • Mon Apr 13, 2026 6:31 pm
DenisSilveira
DenisSilveira
#7 by DenisSilveira
after upgrading V14, better had stayd V12
  • Mon Apr 13, 2026 8:26 pm
QuanNguyen
#8 by QuanNguyen
What is OpenAI?
He/she is studying from you, too. :)
  • Mon Apr 13, 2026 8:55 pm
DenisSilveira
DenisSilveira
#9 by DenisSilveira
using ChatGPT to help develop codes and optimize ...
  • Mon Apr 13, 2026 8:59 pm
DenisSilveira
DenisSilveira
#10 by DenisSilveira
I ran a test, one simples HELLO WORD in Net 4.8.1 netframework and not debgging
when I ran with app Net8 it´s ok
My apps almost 4.8,1 netframework
Might be the problem ?
  • Tue Apr 14, 2026 6:11 am
QuanNguyen
#11 by QuanNguyen
Please refer to the screenshot of the debugging CMS14.1 using NET 4.8
https://www.dropbox.com/scl/fi/0q3q1vgl ... z1bun&dl=0
  • Tue Apr 14, 2026 8:42 am
Return to “VBA, . NET & IRX”
  • It is currently Sat Oct 10, 2026 10:25 pm
