Block with leader
I'm using a block as symbol (for trees)which has several attributes. Often I have the situation, that blocks are on the drawing so close together, that the attribute-text can't be read. Since the text of the attributes is fixed, it's imposible to move it without changing the position of the whole block. Is there no possibility to use leader as part of a block, where the annotation-text is defined as attribute?
Maybe someone has an idea?
regards
geo
When I click on a block with attributes, the grips appear and I can grab an attribute by it's grip and move it without moving the block. Sounds like that is what you need to do.
You need to have grips turned on.
Mars
Indeed,
I remarked it just after posting my question to the forum, that there is no big mystery to change position of the attributes in the block.
Thanks for your reply
Geo
