Zoom Dynamic???
Posted: Thu Feb 15, 2001 7:39 am
by Matt
In AutoCad there is a zoom command called "Zoom Dynamic". Does IntelliCAD have a "Zoom Dynamic" command? I use that command all the time in AutoCAD and I would like to be able to use it in IntelliCAD.
Any help would be appreciated!!
Thanks!!
Posted: Thu Feb 15, 2001 8:09 am
by R.J.Saarikko
If you hold the Shift+Ctrl keys down while
you drag the mouse with right or left button
depressed you get zoom or pan dynamic.
Help MSVCRT.DLL error
Posted: Fri Feb 16, 2001 10:00 pm
by afarnsworth
I can open icad but when i try to do any commands I get this error code MSVCRT.DLL Please help I am under a time crunch.
Aaron
Posted: Tue Feb 20, 2001 8:39 am
by Alberto
hello:
Which ICAD versión are you using?
Posted: Wed Mar 14, 2001 1:52 am
by mjsmyth
Take a look over on the cadopia forum, I came up with a workaround for zd (it is not really zd, but it does enough for me)and someone else cleaned up the code.
Michael John Smyth
Irish / UK Representative
Efnet Autodesk Users Group
www.eaug.org
Posted: Wed Mar 14, 2001 3:05 pm
by MTriche
Mjsmyth,
I tried out your routine and it appears to work great. While this routine may not mimic zd exactly it sure is better than what we had before. I tried your routine and zepps modified one and had no problem with either one. Thank you for sharing this with us. I know I will use it often. With your permission I would like to post it on this forum also.
Melodie
P.S. Congratulations on receiving EAUG Member of the Month award.
[This message has been edited by MTriche (edited 03-14-2001).]
Posted: Sat Mar 17, 2001 9:34 am
by mjsmyth
Melodie,
By all means post it on the forum. I see you must have been looking at the eaug.org site, thatmember of the month award is a bit old now (unless I have won it again somehow) but thank you anyway.
I do have another website,
www.thedraftingshop.com and in the downloads area there, you might find other bits and pieces that could be of use.
Michael John
Posted: Wed Mar 28, 2001 7:15 pm
by MTriche
Michael,
I have added a Bonus forum for helpful things such as your lisp routine and link to your site. I have looked at your tutorials in the past and they are some of the best I have seen. I have often times recommended your site to others that have emailed in asking where they could locate tutorials.
Thank you for the contributions,
Melodie
