I am an electrical engineer and have been using IntelliCAD since it was first released.
All the problems with file compatibility that I have experienced have had to do with others using Architectural Desktop and creating proxy items (you should not have that problem), and with file format versions. Those are the same issues you have with various flavors of AutoCAD.
Drawing interchange is not an issue.
Mars
Thanks, Mars.
No advice on the strange lines, which are just lines, and the plotting problem? We tried recovering and auditing the drawing, found a fixed a lot of errors, but couldn't crack the strange line issue...
[This message has been edited by vivusarchanddesign (edited 01-25-2005).]
Yep, tried that, too: Color by layer. Changing color doesn't have any effect.
Auditing the file seems to shift the problem elsewhere. This applies to text (shx) also. The file came from AutoCad 2004, and an autocad audit didn't fix the problems either.
Could this be some freak video card issue?
