Library
Does anybody know of a quick way to insert Library items into IntelliCAD.
In AutoCAD I use the ***image
section of the AutoCAD Menu to show slides of the Library items and allow selection of the item required.
Is there anything like this in IntelliCAD
The ITC created a "image menu" SDS application to do this. Do a web search for "Image menu" +intellicad and you should find a copy.
I have found several problems, most notibly the images are totally black for me (I use a white background). I figured out I had to edit the DCL file to use a white background.
Other people seem to be able to use it with no problems.
Mars
