PDF is what I would have said but wondered if anyone would suggest anything different. You can't edit PDF's (as images), although why you'd want to...
One thing, I am increasingly being sent PDF files (as substitutes for paper reference drawings and to avoid sending CAD files which people are often loath to share), they are just a giant pain to plot compared with DWG's and serve only as an expedient for the sender. I refuse to use them in any number (70-odd for the latest job). The question is do all PDF's take something like 30 minutes to plot... on an A1 HP which does the same in DWG format in 1.5 minutes?
Why do you do that? Is it so you don't have to recreate the plot parameters if it has to be plotted again later?
I have an impression how long a PDF takes to plot depends a lot how it was created. I created a couple which plotted quite fast but others I was sent took forever.
