extrude
Hello everybody,
please advise .. is there an extrude command in SE? or PE? .. as what from I know .. extrude command is only available in pe+ but our client is insisting that there is a 3d icon for the command in se and pe ... and he is asking why the icon when click ... the function does not work ... I hope to receive expert advise from one of you soon ..... thanks
Lyle
mhylesv,
From the help:
NOTE An extruded body is different from an extruded solid. If you wish to extrude an entity and convert it to a three-dimensional solid, use the Extrude command.
It looks like the extrude was the elevation command prior to PE+ which uses ACIS Solids.
In IntelliCAD 6.1.19.0 PE+, I tried to extrude a polyline and two rectangles along a path created by a polyline with fitted curves but I get "Unable to extrude 2 curve(s)" messages. How can I fix this problem?
