snap to xref - too slow
Posted: Thu Mar 09, 2006 2:44 am
by ferol
snapping to reference drawings is more slower than snapping to normal other entities in drawing... (ICAD6.1.19.1 SE demo, is this bug?
Posted: Sat Mar 11, 2006 10:47 pm
by J. Marsden DeLapp, PE
It has been years since I had access to the source code, but here is what I believe is causing that problem.
When you snap to an entity, IntelliCAD first selects only the nearby entities to work with, then calculates all the end points, intersections, etc (whatever you are trying to snap to) then finds the closest one to the pick point.
But when one of those nearby entities is inside a block, xref or hatch pattern, IntelliCAD will include ALL of the entities inside the block, xref or hatch pattern and instead of calculating possible snap points for a handful of entities, it could be calculating possible end points, intersections, etc for many thousands of entities.
So here is my workaround.
Reduce the size of xref drawings.
Don't use hatch patterns or don't use IntelliCAD 6.0 or 6.1
Mars
Posted: Wed Mar 15, 2006 7:52 am
by ferol
but I tried another ICAD, where this works perfect....
Posted: Fri Mar 17, 2006 1:17 am
Can you be more specific as to the exact Version of ICAD where this works perfectly?
Posted: Fri Mar 17, 2006 12:00 pm
by ferol
cadopia 2006
Posted: Thu Mar 23, 2006 10:20 am
by ferol
sorry, I meen Cadian2006
I tried too much icads ....
