I Would you like a tool that allows me to select existing points in your drawing and places the coordinates next to the point using the current text style. However, I can not seem to be able to get the to the existing points (on the money).
Longo
Longo,
I will begin work on that today. It should be rather simple to write. Thanks for the information.
As far as loading a lisp is concerned there are two ways to do so. The first is the manual way by typing appload at the command prompt and selecting the "Add File" button to find your lisp routine. Once the file is added to the list you will need to select it from the list and click the "load" button. This is the hard way since you have to reload the lisp routine in every drawing you open.
The second way is to have IntelliCAD automatically load the lisp routine each time you open a new drawing. The way to do this is to add a line to your icad.lsp file, which must reside in the same directory as the icad.exe file. If it doesn't exist yet don’t worry, it can be created by opening the windows notepad (a standard text editor) and adding the lines:
(load "mylisp.lsp") ;; Loads lisp routine
(princ) ;; Quietly exits the lisp routine
Save the file as icad.lsp and place it in the same location as the icad.exe file.
If icad.lsp does exist simply adding the above lines to the bottom existing file will produce the desired results as well.
Some final notes about custom lisp routines. “mylisp.lsp” is a generic name for a lisp routine your custom lisp may have another name but the extension will be .lsp. The lisp routines must be located in the same directory as the icad.lsp file is or they must reside in one of the “menu” paths configured for IntelliCAD to use.
To configure your “Menu” path type config at the command prompt and under the “Paths/Files” tab you will find a “User Path” labeled “Menus” you can select it and click “Browse” to browse to the folder where you would like IntelliCAD to look for any lisp routines you request to be loaded.
I hope this information is helpful.
I should have that lisp routine for you early next week.
David Trotz
I have finished your lisp routine. Please check your email.
Anyone else who may be interested in this routine can email me directly at dtrotzjr@programmer.net, otherwise I will be posting it at my new CAD Utilities web site early next week.
David Trotz
There is a type of dimensions, called Ordinate. Check the menu Insert/Dimensions/Ordinate or type "dim" <Enter> "or" <Enter>. Select the point and drag the line horizontaly to display Y-coordinate ou vertically to display X-coordinate.
This comand will display you the coordinates in your current user coordinate system. To change the origin of your coordinate system, use the command UCS. To change text size and font, use DDIM comand.
Maybe this will be fine for you.
Michael Röck
In English:
CCEAB,
Great routine! Thank you for sharing it. I have used babelfish http://babelfish.altavista.com/tr to translate your message as best as I can. And to translate my message to you into Spanish as beast as I can. Please forgive any errors in the translation.
David
In Spanish:
CCEAB,
Gran rutina! Gracias por compartirla. He utilizado http://babelfish.altavista.com/tr del babelfish para traducir su mensaje como mejor puedo. Y para traducir mi mensaje
a usted a español como bestia como puedo. Perdone por favor cualquier error en la traducción.
David
Original Message in english.
Routine of Lisp of command Zoom Dynamic.
- To cancel and to leave without change use key "C " or " c ".
- To accept the Zoom lens press right mouse button
- In order to fix point press left mouse button.
- In the case you need to cancel press ESC. You will be left with ghost images and need to REDRAW, REGEN, or ZOOM to make them dissapear.
- Help Icad stops at function GRREAD (??)
My friend, this is really good!!!!
Congratulations!!!
Amigo mío, la rutina está excelente!!!
Felicitaciones!!!
Alberto
The following is a slight modification to the above lisp routine, by cceab. It fixes the text dumping to the screen at the finish of the command. Enjoy! Thanks again cceab!!!!
;; Zoom Dynamic
;; By "CCEAB"
;; E-mail: cceab@telsur.cl
;; Description of changes by David Trotz Jr.
;; All Changes noted below.
;; Added done variable to check to see if user is done. This check
;; bypasses the call to the exit function which should
;; only be called in an unrecoverable error detected by the program.
;; becuase this is true, using exit also causes IntellicAD to dump
;; the rest of the lisp routine to the screen for debugging.
(defun c:zd (/ fzoom0 ssiz vctr vsiz vasp ssizh ssizv
fvsvh fvshd x010 y010 x030 y030 ip0 it0
it1 fla0 fla1 pto0 done
(setq pi2 (/ pi 2))
(setq pi4 (/ pi 4))
(setq pi32 (* pi 1.5))
(setq an1 pi4)
(setq an2 (+ pi2 pi4))
(setq an3 (+ pi pi4))
(setq an4 (+ pi pi2 pi4))
(setq factzoom 3) ; factor amplicacion zoom
(setq sblip (getvar "blipmode"))
(setq scmde (getvar "cmdecho"))
(setvar "blipmode" 0)
(setvar "cmdecho" 0)
(setq fzoom0 factzoom)
(setq ssiz (getvar "screensize"))
(setq vctr (getvar "viewctr"))
(setq vsiz (getvar "viewsize"))
(setq vasp (getvar "viewaspect"))
(setq xc0 (car vctr))
(setq yc0 (car (cdr vctr)))
(setq ssizh (car ssiz))
(setq ssizv (car (cdr ssiz)))
(setq fvsvh (/ ssizv ssizh))
(setq van1 (atan fvsvh))
(setq van2 (- pi van1))
(setq van3 (+ pi van1))
(setq van4 (- (* 2 pi) van1))
(setq fvshd (/ 1 (cos van1)))
(setq dx0 (/ (/ vsiz fvsvh) 2))
(setq dishd (* dx0 fvshd))
(setq dishd0 (* (* dx0 1.01) fvshd))
(setq vvctr (trans vctr 3 2))
(setq p001 (polar vvctr van1 dishd))
(setq p002 (polar vvctr van2 dishd))
(setq p003 (polar vvctr van3 dishd))
(setq p004 (polar vvctr van4 dishd))
(setq p005 (polar vvctr van1 dishd0))
(setq p006 (polar vvctr van2 dishd0))
(setq p007 (polar vvctr van3 dishd0))
(setq p008 (polar vvctr van4 dishd0))
(setq dd01 (* dx0 0.15))
(setq dd02 dd01)
(setq dd03 (* dd01 1.5))
(setq dx01 dx0)
(setq dishd01 (* dx01 fvshd))
(command "zoom" "_c" vctr (* vsiz fzoom0))
(zdmarco)
(setq vsiz0 (getvar "viewsize"))
(setq p010 vctr)
(setq ip0 1)
(while (and (< 0 ip0) (not done)) ;;; Modified by David Trotz Jr.
(setq ip00 1)
(while (and (< 0 ip00) (not done)) ;;; Modified by David Trotz Jr.
(zdventana 0)
(setq pto0 (grread 1 5 2))
(setq fla0 (car pto0))
(cond
((=fla0 5) ; Coordenada
(zdventana 0)
(setq p010 (car (cdr pto0)))
((=fla0 11) ; mouse derecho
(zdaceptar)
((=fla0 2) ; teclado
(zdventana 0)
(car (cdr pto0))
(zdcancelar (car (cdr pto0)))
((=fla0 3) ; mouse izquierdo
(zdventana 0)
(setq ip00 -1)
(setq pp010 (trans p010 3 2))
(setq p012 (polar pp010 van2 dishd01))
(setq x012 (car p012))
(setq fla1 1)
(setq it00 1)
(while (and (< 0 it00) (not done)) ;;; Modified by David Trotz Jr.
(zdventana fla1)
(cond
(zdventana fla1)
(setq x010 (car pp010))
(if (> x010 x012)
(setq fla1 1)
(setq dx01 (- x010 x012))
(setq fla1 -1)
(setq dx01 (- x012 x010))
(zdaceptar)
(zdventana fla1)
(car (cdr pto0))
(zdventana fla1)
(setq it00 -1)
(setvar "blipmode" sblip)
(setvar "cmdecho" scmde)
(princ) ;;; Added by David Trotz Jr. Exits Quietly
(defun zdaceptar (/ pp010 pp001 pp002 wp01 wp02)
(setq pp001 (polar pp010 van1 dishd01))
(setq pp002 (polar pp010 van3 dishd01))
(setq wp01 (trans pp001 2 3))
(setq wp02 (trans pp002 2 3))
(command "zoom" "_w" wp01 wp02)
(setq done T) ;;; Modified by David Trotz Jr.
(defun zdcancelar (a0)
(if (or (=a0 67) (=a0 99))
(command "zoom" "_p")
(defun zdmarco (/ pp001 pp002 pp003 pp004 pp005 pp006 pp007 pp008)
(setq pp001 (trans p001 2 3))
(setq pp002 (trans p002 2 3))
(setq pp003 (trans p003 2 3))
(setq pp004 (trans p004 2 3))
(setq pp005 (trans p005 2 3))
(setq pp006 (trans p006 2 3))
(setq pp007 (trans p007 2 3))
(setq pp008 (trans p008 2 3))
(grdraw pp001 pp002 200 1)
(grdraw pp002 pp003 200 1)
(grdraw pp003 pp004 200 1)
(grdraw pp004 pp001 200 1)
(grdraw pp005 pp006 200)
(grdraw pp006 pp007 200)
(grdraw pp007 pp008 200)
(grdraw pp008 pp005 200)
(defun zdventana (icod / p011 p012 p013 p014
p015 p016 p017 pp018 pp010 pp011
pp012 pp013 pp014 pp015 pp016 pp017
pp018
(setq p011 (polar pp010 van1 dishd01))
(setq p013 (polar pp010 van3 dishd01))
(setq p014 (polar pp010 van4 dishd01))
(setq pp011 (trans p011 2 3))
(setq pp012 (trans p012 2 3))
(setq pp013 (trans p013 2 3))
(setq pp014 (trans p014 2 3))
(grdraw pp011 pp012 -1)
(grdraw pp012 pp013 -1)
(grdraw pp013 pp014 -1)
(grdraw pp014 pp011 -1)
(if (=icod 0)
(setq p015 (polar pp010 an1 dd01))
(setq p016 (polar pp010 an2 dd01))
(setq p017 (polar pp010 an3 dd01))
(setq p018 (polar pp010 an4 dd01))
(setq pp015 (trans p015 2 3))
(setq pp016 (trans p016 2 3))
(setq pp017 (trans p017 2 3))
(setq pp018 (trans p018 2 3))
(grdraw pp015 pp017 -1)
(grdraw pp016 pp018 -1)
(if (> icod 0)
(setq p015 (polar pp010 0 dx01))
(setq p016 (polar p015 pi dd03))
(setq p017 (polar p015 an2 dd02))
(setq p018 (polar p015 an3 dd02))
(setq p015 (polar pp010 pi dx01))
(setq p016 (polar p015 0 dd03))
(setq p017 (polar p015 an1 dd02))
(setq p018 (polar p015 an4 dd02))
(grdraw pp015 pp016 -1)
(grdraw pp015 pp018 -1)
(princ)
[This message has been edited by dtrotzjr (edited 05-14-2001).]
