somthin' strange
tspco
tspco
Sun Dec 04, 2005 12:01 am
somthin' strange
#1 by tspco
I just opened a drawing when I use the mouse wheel to zoom it dosen't, when I push the center button to pan is dosen't. I reinstalled Icad a few weeks ago and the macro warning shows up when I open Icad it didn't used to. what is going on?
  • Thu Oct 26, 2006 12:41 pm
  • It is currently Sun Oct 11, 2026 8:03 am
