Retrieving elements from Lists
I have written an autolisp program where i generate a list of points that i would like to connect with the SPLINE command. The problem I am having is that I have been only able to get the spline command to recognize the first element of the list automatically. Following is the basic code:
<BLOCKQUOTE><font size="1" face="Verdana, Arial">code:</font><HR><pre>
(repeat 5
(setq pt2 (getpoint ("\n enter point")))
(setq l1 (append l1 (list pt2)))
(command "spline" (car l1))
</pre><HR></BLOCKQUOTE>
As you can see above, this routine will get me the first point in the list l1, however, if I try to loop to get futher points in the list, I am not able to get further in. Does anyone know how to go about this process? Thanks!
Tom
Maybe your problem is you are only testing on the command line. Loop functions don't work well when pasted to the command line only. Also, there is a syntax error in your (getpoint). The little lisp routine below seems to work well:
(defun c:test ()
(setq l1 (list '()))
(repeat 5
(setq pt2 (getpoint "\n enter point"))
(setq l1 (cdr l1))
(command "spline" l1 "" pause pause)
