Door routine Lisp Snippit
Hello,
can anyone help here, I have a door routine that has been working fine in AutoCAD and it does not seem to function properly in Icad.
Here is the code snip.
(command "line" pt1 pt2 "")
(command "offset" d_width (setq hingeside (entlast)) pt3 "")
(setq pt3 (polar pt1 (angle pt1 pt3) d_width))
(setq pt4 (polar pt3 (angle pt1 pt2) (distance pt1 pt2)))
(command "trim" hingeside (entlast) "" (midp pt1 pt3) (midp pt2 pt4) "")
The routine stops at the last line, I am not sure why. All I am trying to do, obviously, is trim between two lines (hingeside and the last line created).
Any suggestions what I am doing wrong?
