Hi People,
Have been trying to employ the block library manager written by "avaernes". Have followed the instructions at "http://autolisp.3utilities.com" and in the download "blib-r15i" (am using intellicad 6.1 pe+).
I can load it successfully; however, when I try to run it I get the error:
"One of the library files needed to run "C:\Icad\Lisp\Blib\doslib14.arx" cannot be found. Can't open "doslib14.arx" for execution XLOAD failed"
The files below are definitely in the search path:
C:\Icad\Lisp\Blib\doslib2k.arx
C:\Icad\Lisp\Blib\Blib_ac.DCL
C:\Icad\Lisp\Blib\Blib_ic.DCL
C:\Icad\Lisp\Blib\Doslib4.dll
C:\Icad\Lisp\Blib\Linnet21.exe
C:\Icad\Lisp\Blib\blib.lsp
C:\Icad\Lisp\Blib\blibhelp.txt
C:\Icad\Lisp\Blib\FILELISTING.TXT
C:\Icad\Lisp\Blib\INSTALL_BLIB.txt
I don't know what file it is looking for.
Can anyone give me a clue.
P.S. in autocad 2005 I get the error:
"ARXLOAD failed; error: An error has occurred inside the *error* functionAutoCAD
variable setting rejected: "cmdecho" nil
[This message has been edited by jamesclane (edited 03-02-2006).]
The *.arx routines will not load in IntelliCAD.
You must use doslib16.arx for AutoCAD 2005
You can get it here: http://www.en.na.mcneel.com/
