I am working on a bill of materials project and have a problem.
How can I control the justification of text?
It seems to default to bottom-left, but I need it middle justified on some columns and left-middle on others.
Also after writing a row of text how can I specify the insertion point for the next row, changing the y-value a certain amount at each row while leaving the x-value the same.
You will need to calculate the location point yourself, no justification available.
Steps involved:
1/ Insert the text in the drawing
2/ Obtain the bounding box for the text (this will give you the lower left and the upper right points)
3/ Calculate the new insertion point.
4/ Move the text.
To find the next point to insert text use
Sub TestText()
Dim objText As Text
Dim TextPoint As Point
Dim NewTextPoint As Point
Dim TextHt As Double
Dim strText As String
Dim I As Integer
strText = "Some Text "
Set TextPoint = ThisDocument.Utility.GetPoint(, "Select Text Position")
TextHt = 10#
Set objText = ThisDocument.ModelSpace.AddText("Some Text 0", TextPoint, TextHt)
objText.Update
For I = 1 To 5
strText = strText & VBA.CStr(I)
Set TextPoint = Library.CreatePoint(TextPoint.x, TextPoint.y - (TextHt * 2), 0)
Set objText = ThisDocument.ModelSpace.AddText(strText, TextPoint, TextHt)
objText.Update
Next I
Steps involved:
4/ Move the text.
Sub TestText()
Dim objText As Text
Dim I As Integer
TextHt = 10#
objText.Update
For I = 1 To 5
objText.Update
Next I
