Grips Active
I want to detect active grips on the screen
and after that a selection set is made through the VBA macro look what I just
think below:
sub GripsAtive()
Dim SS As SelectionSet
Set SS = ThisWorkspace.ActiveDocument.SelectionSets.Add("SS")
if gripsactive then
SS.SelectOnScreen 'selection is made
rest of the code
else
exit sub
end if
end sub
Is it possible to do that
Thank you
AHM
AHM,
Are you trying to return the currently selected objects? That is the objects on the screen selected by grips. If so try:
Private Sub TESTING()
Set SS = IntelliCAD.ActiveDocument.ActiveSelectionSet
'...do stuff with selection set
ssc
