AHM,
You can use the Add-In Manager from Tools-->Visual Basic..-->Add-In Manager... From the Pull-Down Menu.
The .exe or .dll can be set to auto load in VB so that it will be available when you start IntelliCAD.
AHM,
In VB6 when you are setting up the Add-In set the Connect(Connect.dsr) and with the General tab selected set "Initial Load Behavior" to Startup.
There are only two options Unloaded and Startup.
