Dictionaries
Posted: Sat Oct 22, 2005 2:46 pm
by ErikS1
I'm trying to use a dictionary object using Icad 6 PE+, ver 6.0.12.1. Following the general pattern from Autocad, I tried:
Dim count As Long
count =IntelliCAD.ActiveDocument.Dictionaries.count
When I try to run this, I get run time errro 445, object doesn't support this action.
Likewise, if I try to add a dictionary with
Dim Doc As IntelliCAD.Document
Set Doc = IntelliCAD.ActiveDocument
(other stuff)
Dim Dic As Dictionary
Set Dic = Doc.Dictionaries.Add("test_dict")
I get the same error. Any ideas where I am going wrong here?
Thanks,
Erik
Posted: Sat Oct 22, 2005 4:34 pm
by John Finlay
ErikS1,
Looks like a problem in Dictionaries Object as I keep getting errors as well.
Posted: Mon Oct 24, 2005 12:59 pm
by ErikS1
Ah-ha. Thanks for checking into it, I think I can get around it by using object xdata tied to a layer. Not quite as clean a solution, but it will work. Hopefully this will get better in the next upgrade/release.
-Erik
