Selectionset's Select vicSelectionSetAll fails
hello all,
i am new to VBA in progeCAD. But have been working for 4 yrs in autocadb VBA.
i dont know what the prob is following snippet
Dim DXFNumber(0) As Integer
Dim DXFName(0) As Variant
' set the filter options
DXFNumber(0) = 0
DXFName(0) = "LINE"
' add the selection set name to the drawing database
Set objSS = ThisDocument.SelectionSets.Add("SetName")
' populate the selection set with all the drawing entity objects
objSS.Select vicSelectionSetAll , , , DXFNumber, DXFName
This does not work. Eror "Type mismatch occurs"
....so i tried just
but that also pop ups an error
I got it !!!!
ProgeCAD does not support *Late binding techniques" it seems !!!
If i dont put following line before using SSet the code wont work
Dim objSS As SelectionSet
Even if you put
Dim objSS As object
and then use latebinding .. it wont work !!
So NO NO NO latebinding in ProgeCAD.
Bye all!!
[This message has been edited by nm_ranga (edited 09-22-2006).]
