Cursor Menu
Has anyone else noticed this problem using CMS 2001 PE version?
1. 2001 version will not accept a customized POP0 menu (worked in ICAD 2000). I tried importing a custom "shift-right click" menu but when I do it renders the cursor menu non-functional. I even added the additional items through the entity settings customization in the pull down menus but the items do not show up in the right-click menu. Any thoughts????
It did find a workaround (I think it was mentioned a while back in the Bricsnet forum) as follows:
Customize the cursor menu via the pull down menus adding the items desired. Export the menu file, open the exported menu file with notedpad, find the section with the added items and change each items visibility to 1134 (I think its 1134). Import the the revised menu (uncheck box append to menu), the new items should show up. The same can be accomplished if you are adept a editing the registry.
Did I miss something with the cursor menu when editing it?????
Thank you,
Scott
