RMRIBA,
When you select the scroll bars in IntelliCAD it should remember that this is the default when you open IntelliCAD again.
The setting toggle is recorded in the Windows registry. I don't use the scroll bars therefore I haven't checked this out when the versions of IntelliCAD change.
I think it is not in Windows registry, but in a system variable. WNDLSCRL ?
OPen a new drawing, turn on the scrollbars and save the drawing as your template (ICAD.DWG?)
